Overview
Show different dialog types.
Description
This simple example can be used to check the appearance and functionality of a few dialog VIs present in LabVIEW. Run the example. Select the Dialog type to display from the enum control. The dialog appear every 2sec.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Choose the dialog type.
3. Wait until the dialog window appears.
Additional Information or References:
