Overview
This example shows how the dynamic event registration can be used to detect a value change event for any control on the front panel.
Description
This can be used to execute code only when the user modifies values on the front panel. The example also demonstrates that information about which control is modified can be obtained from the CtlRef event data.
Requirements
Software:
1. Run VI.
2. Change the values of any front panel objects.
Additional Information or Resources
Thanks for the great example! It appears that it does not catch change events if the control on a tab control.
Is there any updates? Also searching a way for catch change event of any control inside a tab control.
Got it. Wire the property node of TabControl-Pages (index it or index with a for loop)-CtlsOnPage to the input of input of Reg Events.
