Functional Description
This procedure shows how to create a DataBase in Windows XP and its Connection File to use in LabVIEW with the DataBase Connectivity Toolkit.
Where is the file?
Sorry for the inconvenience, the file has been uploaded.
I have developed utility to write / generate UDL file
Link is
https://decibel.ni.com/content/docs/DOC-18612
i need create udl file for access 2010, can you help me?
Nice document. Yet, this way of creating a udl file will show the 64-bit version of the Data Link Properties dialog (that will not work with the LV Database Connectivity toolset for example) if you're running a 64-bit Windows. To force it to 32-bit, you have to type a pretty long command line, or just go to Tools -> Create Data Link in LabVIEW.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
