Overview
Demonstrate how to test database connection and fetch the data using the SQL query. Provide SQL query based on your database setup.
Description
When accessing database using LabVIEW, ActiveX or Database connectivity toolkit can be used. Database connectivity toolkit is a addon to LabVIEW.
Common steps to connect with database when using Active X or Database connectivity toolkit are similar .
Requirements
LabVIEW 2013 (or later)
Additional Images or Video
I guess I need the database connectivity toolkit to run the exmaple project?
I wanted to create a table using Labview database connectivity toolkit functions and also wanted to assign a Primery Key and Foreign Key using labview in SQL database table.
is this possible using Labview database connectivity toolkit functions.
Srikant
Zip folder doesnt contain Example for ActiveX
