Example Code
Creating an Enum Using VI Scripting
Code and Documents
Overview
This example VI demonstrates the method to programmatically create an Enum using VI Scripting.
Description
The VI first creates a new VI at the path selected by the user in the File Dialog. It then opens a reference to the Block Diagram of this new VI and feeds this into a New VI Object function that creates an Enum Constant. This constant is then populated with the items from the String Array Control.
Once it has done this, and closed off the references, it saves the changes to the VI and then opens it for you to view.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " VI Scripting - Creating an Enum Constant 2012 NIVerified.vi"
  2. Enter all the Items you want to be in your Enum into the String Array Control
  3. Run the VI.
VI Snippet
James W
Controls Systems Engineer
STFC
Comments
EWiebe
on
Thank you very much!
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
1ERC
on
James_W,
WoW! - I developed an idea that would allow an ENUM to be used for accessing the correct constant in a meaningful way, thought "this would be great for a script, if I knew how" and actually found the answer on NI's site - FANTASTIC!!!
HOWEVER! - The criminal/evil Wallmart Money-Grubbing mentality has struck again:
  o  Despite insane SW prices that prevent me from owning up-to-date LV at home, NI refuses to provide reliable support
  o  My employer will not provide up-to-date LV at work
  o  You did not provide an example I can use with LV 2010
ThanX?
1ERC
JTG_Wilson
on
Hi 1ERC,
I'm sorry that you've had difficulty getting support from NI engineers but, despite what my profile on here might say, I'm no longer an NI employee so can't really do anything to help you there. I have, however, added a version of the code saved for LV2010 so hopefully you'll now be able to try out the example.
James
James W
STFC
1ERC
on
ThanX James,
After I wrote the nastyGram from exasperation, I was able to re-create the Script from the fuzzy picture and IT WORKED! I will compare it to your kind 2010 ENUM Script.
ThanX again and best regards,
1ERC
MatiasMan
on
This help me a lot to create a beautiful polymorphic vi.Smiley Happy
