Creating a Case Structure and Populating the Cases using VI Scripting
Codice e Documentazione
Allegato
Overview
This example VI demonstrates the method to programmatically create an Case Structure using VI Scripting.
Description
The need may arise within a program to update the values of a control such as an Enum or Ring Control during Run Time. In this case there are a couple of things to be aware of.
Firstly, this is possible by VI Scripting as can be seen here and here. Secondly, the method used to update the Text Ring as in this example can not be used for Enumerated Controls - this alone can be done by VI Scripting. In the following VI, a simple Property Node can be created from Right Clicking on the Text Ring Control in question. The property to be selected in this case is Strings[].
In this case, it is put in a little more context by the String Search functions used to populate it - this could be any string from any source.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " Ring Changer 2012 NIVerified.vi"
  2. Fill the Original String Values with whatever Values.
  3. Run the VI.
James W
Controls Systems Engineer
STFC
Il codice di esempio scaricato dall'Example Code Exchange nella NI Community è concesso in licenza con la licenza MIT.
Commenti
Herlag
su
Hi James,
Nice and useful job.
HL
ChuckS
su
I agree nice ... saved me some work
Frank_Pontes
su
HI James, would you be so kind to save the file so it is compatible with Labview 2010?
Varunesh
su
great
eldiego
su
Great job, James!
Is it possible to do the opposite? Create and populate an array of strings where each string is the case label.
CLA
JTG_Wilson
su
Hi Eldiego,
You can probably do what you are asking by using the FrameNames property node. If you search in the example finder for 'scripting' and load the VI Scripting with Structures - Case Structure.vi it will show you various properites for case strucutres that you can get and set using VI scripting.
I hope this helps.
James W
STFC
tmccrack
su
Nice, just used this for generating cases for a queued state machine. Thanks
