Overview
This VI allows us to quickly convert a single VI or a whole folder full of VIs to a previous version to provide compatibility.
Description
Often when developing applications we need to be save applications to previous version in order to move them from one system to another. This applications allows you to select a VI and convert that VI to a previous version. The benefit of using this application is that you are not limited converting a single VI at a time and can actually convert whole folders of LabVIEW code to a previous versions.
Requirements
VI Block Diagram
I am feeling that the labVIEW runtime is not at all robust.. As when we after we updated labVIEW to the newest version, whether the VI or proj files whichever were written in the older labVIEW versions are not able to accomodate in the newer versions and also give us error or ask us to install related packages/patches. This is the major loop hole
