Overview
This VI compares a current value to a maximum and minimum value.
Description
This could be useful to classify values that fit into a user-specified range. For example, it could be modified to verify which percentage of a collection of data fit into a range.
If the value falls outside of this range, then the last value that fell within this range is passed.
Requirements
LabVIEW Base Development System.
1. Open the attached VI named “Compare Values between Maximum and Minimum LV 2012 - NI Verified.vi”.
2. Run the VI.
3. Change the values of the upper and lower limits and the number to analyze.
In Range and Coerce.vi
