Example Code
Clearing a Specific Error From The Error Cluster
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to define a specific error in your code and when this error appears while running the code, you can clear it from the error cluster.
Description
While the best error practice is to handle all errors, there may be times (such as user defined errors) where the user may want to simply clear an error. LabVIEW has a built in function called "Clear Errors" that will clear any error in an error cluster. In order to selectively clear an error with this VI, you need to check the error cluster first for your specific error, and then use the "Clear Errors" function.
The attached example creates a new SubVI that allows a user to input a specific error (or array of errors) and then clear the error cluster when the appropriate error code is seen in the error cluster. The SubVI is implemented as a polymorphic VI and is a good example of dynamically adapting to terminal inputs as well. The input can either be a single numeric error code or an array of numeric error codes to check and clear. This example performs the following:
  1. The VI compares the error(s) that occurred with the error(s) you wish to clear.
  2. If the errors are found we clear the error cluster.
Requirements
LabVIEW 2012 (or compatible)
  1. Download the attached Zipped folder "Clear Specific Errors Polymorphic_LV2012_NI Verified"
  2. Open the project and launch the Clear Specific Error (main) VI
  3. Run the VI
  4. Choose from the tab to clear a single error or an array of errors
Block Diagram
Front Panel
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
Comments
Todd S.
NI Employee (retired)
on
Great stuff Captain!  Please add "LabVIEW" to the tags.
Todd S.
LabVIEW Community Manager
Captain_Kirby
on
Thanks! Added the tag (and a few others.) Also fixed my screenshot (I hate when I can see the selection boxes on case structures in a screenshot.)
Asa Kirby
________________
Sail Fast!
crossrulz
Knight of NI Knight of NI
Knight of NI
on
Be sure to check out the OpenG version of this VI.  I think you need LV2009 to run those.  But we tweaked to get a little better performance than these will for the searching.
