Example Code
Change DAQmx Device Alias Programmatically
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example demonstrates how to programmatically change the alias of any device using LabVIEW.
Description
Device aliases show up as Dev1, Dev2, Dev3... by default, but often you will change those to more meaningful names. Programmatically changing the device name may come in handy when distributing applications to multiple systems. This example could be used to change your NI PCIe-6321 to X-Series in an initialization sequence, and then reference it as such in the rest of your application.
Requirements
Software
  • LabVIEW 2012 or compatible
  1. Retrieve list of all DAQmx devices.
  2. Iterate through list of devices to find desired device.
  3. Change alias.
Comments
zlavick
on
Hi!, I've got this error:
     Error -2147467259 occurred at nisyscfg.lvlib:Rename Alias.vi
     Possible reason(s):
          LabVIEW:  (Hex 0x80004005) Unspecified error.
          NI System Configuration:  (Hex 0x80004005) Miscellaneous operation failure.
Example on Windows host works without any problem, but on RT Target it generates this error (outputs for products and device aliases are correct).
Problem with drivers? Can it be solved?
D_Biel
on
Zlavick,
I did not have RT in mind when I originally wrote this example, but it should work. I was able to run it on my RT target without errors. How are you viewing your errors? Have you made any modification to the original code I posted?
zlavick
on
I'm using your code without any modification, just setting Device=NI PCI-6221 and New Alias=Dev4 (now it is Dev2).
ProdName's array getting correctly:  NI PCI-6229, NI PCI-6221. And aliases too: Dev1,Dev2. So, "system session" refnum is alive.
Before "Rename Alias.vi" have no errors.
I've tried to set "session in" to localhost  (and run it @ RT Target) and tried Remote Target (and run it @ my win host), but the result is the same - error.
May be trouble with my RT's software?
>Error -2147467263 occurred at nisyscfg.lvlib:Rename Alias.vi
That error code is "Not implemented".  What it means is that the version of DAQmx you are using does not implement the Rename functionality.  It was introduced in DAQmx 9.2 if I recall correctly, so try updating to that version and it should work. Source.
But my DAQmx version is 9.2.1... What is DAQmx version at your RT target?
D_Biel
on
I am using DAQmx 9.4 and System Configuration API 5.0. I could not find any bug fixes that would affect this, but that can be hard to tell sometimes.
If you run a project with just the ChangeAlias.vi in it, do you still receive the error? You could try debugging it from LV and see specifically which function is causing the error.
zlavick
on
1. To run "ChangeAlias.vi" i need "resource in" input, and i can't get it without other "sys.conf" vi's. If i running only in "ChangeAlias.vi" in empty VI, i'm getting expected error:
     Error -2147467261 occurred at an unidentified location
     Possible reason(s):
           LabVIEW:  (Hex 0x80004003) Invalid pointer.
     NI System Configuration:  (Hex 0x80004003) A required pointer parameter was NULL.
2. Now i'm using DAQmx 9.4 & Sys. Confg. API 5.0 too, but error still with me.
3. "ChangeAlias.vi" is password protected, how can i debug it?
zlavick
on
SOLVED!
The problem was too strange.
