Overview
This example VI demonstrates the use of XControl to build a simple calculator.
Description
This VI demonstrates how to use a LabVIEW XControl. The Calculator XControl can manipulate values similar to a handheld calculator. The value of the XControl is the current calculated value shown in <b>Output</b>.
Open the Calculator XControl Project included with this example to see the configuration of the XControl.
Requirements
VI Snippet of "Calculator Example.vi"
All functions are prefect, but this Xcontrol only have one question,init. When I stop the process, not close the example VI.Then restart it, the output's value is not the initial one.
PS:My Xcontrol:Login, need to be called by main.vi many times, so it need to be init. But input control cannot be put into the state.ctl.
So, I need help
