Example Code
Calculate Phase Correlation Using LabVIEW
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI demonstrates calculation of the phase difference between two waveforms using the phase correlation method.
Description
There are many applications where it is important to get the phase correlation between two waveforms. The correlations test VI generates two sine waves with different phases and feed them into the time delay VI, and the time delay VI (subVI) will then compute the phase correlation and the time delay in number of samples between the two waveforms. Note that both waveforms must have the same number of samples in them. About phase correlation, see wikipedia article http://en.wikipedia.org/wiki/Phase_correlation
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached files and put them in the same folder.
  2. Open the correlations test VI.
  3. Set up the phase for A and B waveform.
  4. Run the VI and see the phase correlation between the two waveforms on the front panel.
VI Snippet
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
Comments
PhilG
on
So how about a version that we can open - I would imagine that no one outside of NI has LV 9 yet - I know it says LV8_2 but my LabVIEW 8.6 says it is LV 9 and won't open it.
Downloads:
Doug_L._Bear
on
Sorry about that, simple mistake on my part.  Thank you for bringing that to my attention Phil.
Doug Farrell
