Overview
The Boolean to Enable_Disable VI converts a Boolean FALSE or TRUE value to an enumerated type with a value of Enabled (0) or Disabled and Grayed Out (2), respectively.
Description
The Boolean to Enable_Disable VI converts a Boolean FALSE or TRUE value to an enumerated type with a value of Enabled (0) or Disabled and Grayed Out (2), respectively. The Boolean to Enable_Disable VI provides space-saving attribute control within your applications.
The Boolean to Enable_Disable VI outputs an enumerated type (Enabled (0) or Disabled and Grayed Out (2)), allowing you to easily see the state passed to your property nodes when using probes or execution highlighting while running your VI.
Below is an image that contrasts typical attribute control with the space-saving attribute control provided by the Boolean to Enable_Disable VI.
Requirements
VI Block Diagram
Developed by
Mark Ridgley
gives type error???
larall,
Thanks for taking the time to notify me of the issue with this code.
I have updated the code and reposted it with File_Added dates of 2012-11-08.
Mark Ridgley
