Example Code
Benchmarking DMA Read Methods
Products and Environment
    Hardware
  • CompactRIO|SingleBoardRIO
    Software
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates benchmarks of the CPU load when using different methods of DMA FIFO communication.
Description
DMA FIFOs are an efficient method for streaming data from and to an FPGA. DMA stands for Direct Memory Access and DMA FIFOs are able to read/write data directly from/to the Real-Time's memory without causing too much load for the CPU.
In case the DMA FIFO transfers data from the FPGA to the Real-Time system, the data placed in the memory has to be read by the Real-Time application from the memory. For this operations there are several techniques to perform that tasks that differ in CPU load and whether the technique returns a fixed number of elements or a variable number of elements.
  1. Blocking
    This technique has an infinite timeout waiting for a certain number of samples to become available.
  2. Polling
    This technique will read whatever elements are available at a fixed rate.
  3. Polling with a Fixed Number of Elements
    This technique specifies a timeout and the number of samples to wait for.
  4. Blocking with IRQs
    This technique uses an interrupt (IRQ) to synchronize with the FPGA.  When the FPGA has written the desired number of elements to the DMA FIFO the FPGA triggers the IRQ.  The Real-Time application waits on the IRQ and then read the FIFO knowing that the elements are available.
  5. Polling for a Number of Elements
    This technique periodically checks how many elements are in the queue.  Only if there are at least the requested number of elements available the application reads the requested number of elements.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • LabVIEW 2012 Real-Time Module (or compatible)
  • LabVIEW 2012 FPGA Module (or compatible)
  • NI-CompactRIO 13.0 (or compatible)
 Hardware
  • any NI FPGA hardware that supports DMA FIFO data transfer (e.g. NI CompactRIO, NI R-Series, NI FlexRIO)
  1. Run the RT.vi
The test was performed with a CompactRIO-9076 and LabVIEW 2012 and NI-CompactRIO 13.0:
Method CPU Usage (%)
Blocking 96
Polling 19
Polling with Fixed Elements 92
IRQ 17
Poll for Size 11
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Comments
D60
on
That would be great if U downcast it to LV09! Thank you!
+++ In God we believe, in Trance we Trust +++
[Hungary]
lewboi
on
really helpful, cheers
