Example Code
BPSK Example in the Real Plane
Products and Environment
    Hardware
  • PXI|VXI
  • RF|Wireless
    Software
  • LabVIEW
    Driver
  • NI RF Device Drivers
Code and Documents
Overview
Simulation of the behavior of filters on a PSK modulation scheme.
Description
This code simulates how the noise impairment, filters and amount of bits can affect a PSK constellation. A symbol map is already created, however, we are able to change it to another one we would like.
Requirements
1. LabVIEW 2015 (or compatible)
2. NI Modulation Toolkit
1. Open the "Mapping PSK Constellation Using Modulation Toolkit LV2015 - NIVerified.vi"
2. Set the amount of bits to simulate.
3. Select filter to use.
4. Adjust the noise impairment.
5. Run the VI.
Christian A
Applications Engineer
Comments
sgs111
on
Can you share this simulation's document?
