Overview
The example is to demonstrate how to open an excel file with the feature of auto fit enabled automatically
Description:
By using the file reference and New Report VI, we could practically make a new report file in the xls format that would be processed into the format of auto fit so by the time the file is opened, the user could face the file represented in the auto fit format
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Sarci1,
thank you for this VI and guidance with good explanation.
The example for LV 2010 worked great. Uses the active Excel spreadsheet, so simply use the Report Generation Toolkit to select the desired spreadsheet before using this method. Will attach a VI that workes in flow after this comment.
