Example Code
Array(Table) Background Colors based on Thresholds Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This VI generates a random set of data and formats into an array. This array is then passed into a table where the background color of the cells is modified dependent on the individual cell's data value
Description
This VI generates a random set of data and formats into an array. This array is then passed into a table where the Background color of the cells is modified dependent on the individual cell's data valueThis application could be easily adapted to operate on real-world data and alert a user of values outside the expected operating conditions e.g. Extreme Temperatures.
Requirements:
  • LabVIEW 2012( (or compatible)
  1. Run the vi.
  2. Modify the higher limie and lower limit to change the background color
Jamie Jones
Applications Engineer
Comments
Fred_A
on
Thank you for this nice VI. Can you add an other VI with an older version of LV please ?
Jamie_J
NI Employee (retired)
on
Thank you for the comment Fred. Added version for LabVIEW 8.6.
Jamie
Jamie Jones
SwapsG
on
Thank you for this vi. helpful for me.
$waps.
Zbigniew_StS
Member Member
on
The good point is to use property node : Defer Panel Updates before and after operating at table property.
Regards
Mikrobi (Zbigniew St. Sobków)____________________________________________________________
"You can lead a horse to water, but if you can get him to float on his back you've got something."
Y.Ueno(退職)
on
It may use the following KB to initialise the GB color.   http://digital.ni.com/public.nsf/allkb/B8700C12AC7CE927862569DD0063CB0A?OpenDocument
