Demonstrates how to trigger an Analog Output task to begin with a rising edge on a trigger line and end with a falling edge while forcing a return to 0V when the task ends.
This VI shows how to use a digital trigger line to both start and stop an Analog Output task while ensuring that the output returns to 0V after execution.
HW: DAQ device with two available DI and one available AO line
SW: DAQmx
Ensure that the trigger signal is available on both digital input lines simultaneously to be used in the Start Trigger and Digital Input task.
I am completely new to LabVIEW and getting trouble regarding triggering the analog ouput. I am in the stage of similar requirement where i need to trigger analog output signal using digital one.The use of digital edge is clear to me.But,what does port/line mean? Can you please elaborae it? How do I hardware connect them?Should I physically wire port0/line to PFI.
Regards.
Cross posted here.
