Overview
A real-time controllable simulator was created for the purpose of test-flying the aircraft and for testing various feedback control inputs. The following figure illustrates the graphical user interface (GUI) for the simulator.
Figure 1: graphical user interface for simulator
GUI display features
Control inputs
Control input options
Simulator configuration parameters
Joystick Control
The simulation can be controlled in real-time through the use of a joystick. While it's possible that any generic joystick might work with this code, I am only able to guarantee compatibility with the Logitech Extreme 3D Pro joystick. The following figure illustrates the mapping of joystick axes to aircraft control surface input.
Where: Y = elevator control X = aileron control RZ = rudder control Throttle = motor power |
Figure 2: Joystick configuration for simulator control
Theory of Operation
The following is a summary of the process for simulating the aircraft response in real-time:
The state space obtained from FlatEarth is illustrated in Figure 3:
Figure 3: FlatEarth state space output to Labview
The state space variables, inputs, and outputs are defined in Table 4.
Figure 4: State Space Variable Definitions
State Space Feedback Control
It is desirable to be able to apply proportional feedback control gains to the aileron, rudder, and elevator for aircraft testing. The figure below illustrates how the open-loop state space is wrapped by a proportional controller.
Figure 5: proportional feedback controller applied to state space [10]
With the addition of the proportional controller, the state space equation can then be written as: [10]
User-Guide
Installation
You will need to install the following elements before being able to run this code:
Please note that LabVIEW 2015 and the Control Design and Simulation Module can be downloaded/installed for free for a 7-day trial. You can extend this to a 45 day trial by creating a free National Instruments account. You can extend this to a 6 month trial by verifying your status as a student to National Instruments.
Create & SIM a new Aircraft
Step 1: Create FlatEarth constants input file
This is where you specify all the properties of your aircraft. FlatEarth will use these inputs to generate the state space that LabVIEW utilizes to run the simulation. Simflight comes packaged with 3 example constant input files: "Basic_Constants_MPX5.m", "Basic_Constants_PA_28_161_Warrior.m", "Basic_Constants_Albatross.m"
Step 2: Run FlatEarth to Simflight script
Locate the file: "FlatEarth_to_Simflight.m". This script wraps and runs the FlatEarth module to generate a state space. The resulting state space is exported into a set of text files that LabVIEW will parse at run-time. You must edit this script to properly identify and run the constants input file that you just created.
Step 3: (Optional) Modify SIM_Controls.INI
If the FlatEarth code ran successfully, you will have created a new folder in the config_files folder. It should look like this:
The newly created folder contains all of the text files (state space variables) required for the LabVIEW simulation. One file that you may wish to modify is the SIM_Controls.INI file. This files looks like this:
These numbers affect the range of motion of the joystick in the simulator. More specifically, if the max rudder is set at 25 degrees, then full rotation of the joystick yaw-axis will yield 25 degrees rudder deflection in the simulation. If you find that you want a more/less sensitive joystick, you can increase/decrease this number as you please. Simply edit the file and save. LabVIEW loads this file at run-time.
The max_speed input in slightly different. This simply affects the maximum number shown on the speedometer on the GUI.
Step 4: Run LabVIEW Simflight program
Locate and run the file: "Simflight.vi". Again, for this step, you will need both LabVIEW 2015 and the Control Design and Simulation Module installed. (Click the run-arrow in the menu-bar of the VI to start the program.)
Step 5: Specify SIM Inputs
When the program is started, the user is promted for the following information:
Step 5.1: joystick (autodetect) control option
This option will attempt to autodetect a Logitech Extreme 3D Pro joystick plugged into the computer. If successful, you'll be able to control the simulation in real-time with the joystick.
Step 5.2: joystick (select port) control option
If the auto-detect option isn't working, you can use this option to manually specify the port that your joystick is plugged into. This option might be useful for attempting to use the simulator with a different type of joystick. (Again, I can only guarantee compatibility with the Logitech Extreme 3D Pro joystick.) Use device manager to determine what port your joystick is plugged into.
Step 5.3: step function control option
This option will apply a step-function to the state space. Note the following:
You do not need a joystick for this method
Step 5.4: doublet function control option
This option will apply a doublet-function to the state space. Note the following:
Step 5.5: ramp function control option
Data Analysis
The results of the simulation are automatically saved to a MATLAB data file (.mat) at the conclusion of the simulation. These data files can be found in the datalogs folder. It should look something like this after having run a few sims:
The filename is simply a timestamp of when the file was created at the end of the simulation. These files can be loaded directly into the MATLAB workspace using the "load" command. (These are simply Level-5 .mat variable files.)
GUI Interface Description
The following images describe the GUI interface and the meaning/usefulness of various elements.
.png)
.png)
.png)
Simulation Validation
Simulation Validation - Longitudinal Direction
The longitudinal model was tested by injecting a doublet input on the elevator. More specifically, the elevator was deflected -1 degrees from trim for 1 second, then deflected +1 degrees from trim for 1 second, and then brought back to trim. The following figures show the FlatEarth output and Labview simulation output.
Figure 6: FlatEarth - pitch rate response to doublet elevator input
Figure 7: Labview simulation – pitch rate response to doublet elevator input
We see that the nonlinear FlatEarth, linear FlatEarth and Labview simulation results are all in acceptable agreement for pitch rate response to elevator commands. As such, the following can be concluded:
We also see that with an elevator deflection, the pitch rate dampens out and approaches a steady state value of zero. This corresponds to a dynamically stable aircraft in the longitudinal direction. This observation is in agreement with the flight qualities analysis.
Simulation Validation - Lateral Direction
The lateral model was tested by injecting a doublet input on the aileron control. More specifically, the aileron was deflected +1 degrees from trim for 1 second, then deflected -1 degrees from trim for 1 second, and then brought back to trim. The following figures show the FlatEarth output and Labview simulation output.
Figure 8: FlatEarth - roll and yaw angle response to doublet aileron input
Figure 9: Labview simulation – roll and yaw angle response to doublet aileron input
We see that the nonlinear FlatEarth, linear FlatEarth and Labview simulation results are all in acceptable agreement for yaw angle and roll angle for approximately 7 seconds. After this time, the linearized solution begins to diverge from the nonlinear solution. This is to be expected as the linearized solution is only valid near trim conditions. At t=7 seconds, the aircraft is in a deep spiral dive - far from steady-level flight. We can conclude the following from these results:
We also see from these figures that the aircraft is unstable in the lateral direction. As the aircraft rolls and yaws in one direction, the angle grows over time. This is in agreement with the flight quality analysis which found the aircraft to be unstable in the spiral mode.
Tutorial Video
Code Version Control:
The most recent code version can always be found at my GITHUB page:
Acknowledgements
1) Aircraft indicators taken from project here
2) Aircraft gimbal taken from project here
3) FlatEarth written by Professor Andriasani
Great work! This is what the developers forum should showcase! Kudos
