Example Code
3D Sensor Mapping Example
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This example allows you to load a 3D model (4 models are provided), place sensors on the model and map simulated sensor data to the model.
Description
New way to visualize acquired and simulated data in your VIs: 3D sensor mapping.  Using a basic Express VI, you can import a 3D CAD model, assign sensors, and map DAQ channel data directly onto the model.  This example illustrates how to use this feature.
Requirements: LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
  1. Run the VI.  By default the VI will use automatically simulated data
  2. Press the LED to toggle between automatically generated values and input values from the sliders on the left of the 3D picture control
  3. Navigate to the block diagram and double click on the Sensor Mapping Express VI to open its dialog window.
    1. Left click anywhere in the window and drag the cursor to rotate the model.
    2. Hold the Shift key, left click, and drag the cursor to zoom in and out.
    3. Hold the Ctrl key, left click and drag to move the model to a new position in the window.
Additional Information or References:
Todd S.
LabVIEW Community Manager
Comments
Trin
Member
Member
on
Is it possible to use Scene Mesh refrenece instead of CAD file? I need to use this VI but my input can not be represented as CAD
Mads
Active Participant
Active Participant
on
Has anyone modified this function to use a different sensor geometry than a singular point? I'm interested in being able to make the sensor a continous line along the surface of the structure (the measurement does not represent the value at a point, but rather the average along a geodesic path...).
