This example demonstrates how to implement a 1-D median filter in LabVIEW FPGA.
Median filter is a common non-linear filter for signal processing. It is often used to eliminate the noise in images or other signals, especially the speckle noise or salt and pepper noise. The median filter will smooth the signal while reducing the noise. The median filter runs throught the signal point by point, replacing each point with the median of the neighbouring points. Since it is a non-linear filter, we can't simply exchange a median filter with the downstream processing step, thus, we have to do it on the FPGA target to save the calculation on host PC. This example shows a prototype of 1-D median filter on FPGA.
The filter will filter the signal point by point using an 11 point window. You can expand this window by modifying the VI (see VI comments). You can use the "Host test.vi" to compare the performance of the median filter implemented on the FPGA with the results from the "Median Filter" VI from the Signal Processing palette.
Requirements
Software
Hardware
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
If you have any problem to run this example or want to create a reconfigurable median filter, please contact the author: Lei Song, National Instruments, *Lei.song@ni.com.
This is very useful filter. I use it in my application to reject outliers. Works great.
The only issue is that it is difficult to extend this code.
I would love to see a document with this filter that explain what exactly need to be changed when you want to extend (change size) the filter.
I would also love to see this filter in the FPGA tools.
Thanks for the code Lei
Amit Shachaf
The window size can be easily extended by using an indexing tunnel to initialize arrays:
