11-30-2005 12:07 AM
We have
configured such that the FPGA vi waits for clock pulse from PXI star line (Oversample clock). But
the FPGA vi
does not seem to realise any clock inputs in the PXI star line and
keeps waiting at that point.. Is there any different configuration
required either in DSA or FPGA vi’s for sharing the oversample clock .
Slot 2-6- DSA cards
Slot 7- PXI 7833R
Kindly help us on this issue
Regards
Sahana
11-30-2005 10:35 AM
First, I wanted to mention that while the Multi-Device Synch-Analog Input-Cont Acquisition.vi will work, as of DAQmx 7.4, you can now create channels from multiple DSA devices in a single task. When created within a single task, the driver will automatically take care of routing the appropriate clocks and triggers for you to achieve synchronization. This may make your programming a little cleaner and easier.
Second, the example you are using only takes care of synchronizing the DSA boards and doesn't export any clocks or triggers to any devices outside of the DAQmx driver. To do this, you need to use the DAQmx Eport Signal Property Node to export the sample clock timebase from the device in slot 2 to the appropriate star trigger line. The star trigger lines are listed in the I/O terminal control as PXI_Star0, PXI_Star1 ... PXI_Star12. In order to see the star trigger lines in the I/O control, you will need to right click on the I/O control, select the I/O name filtering... menu, and ensure the Include Andvanced Terminals check box is selected. PXI_Star0 corresponds to the star trigger line connecting slots 2 and 3, PXI_Star1 corresponds the star trigger line connecting slots 2 and 4, and so on. In your case, you're trying to connect slots 2 and 7 so you'll need to use PXI_Star4.
The attached program illustrates creating channels from multiple devices in a single task as well as how to export the sample clock timebase to the designated star trigger line.
12-02-2005 06:27 AM
12-02-2005 07:44 AM
Sahana -
Here's a good KB which has several different examples programs concerning how to synchronize DSA devices in DAQmx:
KB 3EE7N2NQ: Synchronizing DSA Devices in DAQmx
The last example should be the most interesting to you as it shows how to manually export different timing signals (such as the start trigger) from the DSA device to PXI_Trig lines.
-Jack
12-04-2005 09:49 PM
12-05-2005 08:35 AM
Sahana,
Just to clarify how the trigger bus is set up:
The Star trigger lines are unidirectional and go from slot 2 to each of the other slots starting with slot 3. The names for the Star trigger lines are offset for each of the slots. Slot 3 Star trigger line is called "PXI_Star0", Slot 4 is "PXI_Star1" and so on. So the Star line for Slot 7 is "PXI_Star4".
The other PXI Trigger lines are bidirectional and go across the entire backplane so that any device in slot 2 or higher can source or receive triggers or other timing signals on these lines. If you source StartTrigger from Slot2 on "PXI_Trig2", then you would listen for the StartTrigger on "PXI_Trig2" in any other slot(s). So in your FPGA code for the 7833R in slot 7, you would poll "PXI_Trig2" to wait for the trigger. You can only source the trigger to any given PXI_Trig line from one device (otherwise you risk damage to the hardware), but you can receive the trigger on multiple devices.
Craig
