Dynamic Signal Acquisition
shifting peak frequency
Many thanks, Doug,
I have shared the code and other information in a pdf file except for the data.
Kind regards
Jaefer
Message 11 of 13
(1,482 Views)
If less than 10sec capture does not reproduce the issue, I would suspect it is your signal shifting. I am not familiar with your application to comment if it is expected for the signal to shift in frequency over time.
I guess you're trying to create a spectrogram (time vs frequency spectrum) and a real spectrogram/sonograph plot would make better sense than multiple plots for each segment of capture.
Santhosh
Soliton Technologies
Message 12 of 13
(1,477 Views)
@Jaty22 wrote:
Thank you, Henrik,
I don't expect any frequency shift.
Happy weekend to you too.
Jaefer
Well, we don't know your setup, but if I think of a tank with a liquid (water) and a bubble source (air tube with nozzle), some influences come into my mind:
1. temperature change-> viscosity (or other properites of both media)  change -> rate change   and/or  the nozzle diameter will change with temperature
(whatever setup you (one) build, if you look close enough, you always build a thermometer :D)
2. turbulences/streams. your bubbles or other sources (temp 😉 , ...) create streams in the water, that also can have an influence of the physics on how the bubble comes off the nozzle
3. you need a stable air/gas pressure ... if you measure (coarsly) the frequency to pressure ratio you get an idea on how stable your pressure needs to be.
4. Any  vibration in the tank /nozzle will have an effect.  Your water tank has it's own resonances (more than one mode) .. your bubbles will exite these resonances .. maybe you see some beat frequencies 🙂
5. ???
time for my first coffee 😄
Greetings from Germany
Henrik
LV since v3.1
Message 13 of 13
(1,472 Views)
