le 05-30-2006 08:02 AM
le 05-30-2006 11:45 PM
Dear Jacob,
It would be helpful if you send the clip of the graph of the Phase versus frequency i.e some data
and what is the expected result , frequency of the sine wave
Thanking You,
K.Narayanan
le 05-31-2006 08:22 AM
le 05-31-2006 09:42 AM
Hello
I would like to measure the delay through both AI and AO and also the delay from AO to AI.
I have looked at the Measure Propagation Delay(DAQmx).vi but i couldn't get it to work properly. How can it be modified to work with my soundcard?
Jacob
le 06-01-2006 12:23 PM
Hello NaruF1
I haven't got a phase versus frequency graph so far. I have just tried to generate a 500 Hz sine to the output channel and then measure the phaseshift at the input channel.
I have attached the file i am using to measure the phase. Everytime i run the program a different phase is measured.
regards
le 06-05-2006 12:06 AM
le 06-05-2006 12:30 AM
le 06-05-2006 10:33 AM
le 08-25-2008 03:52 AM
We have used the sound card delay vi which was attached in the thread for our application. We get different(approx doubled) latency values when sampling rate is different.
Say if the Sound input function sampling rate is 44100 latency observed is in the range 2-4ms
If sampling rate is 22050 latency observed is in the range 4-6 ms for the same microphone.
We are playing the pulse @ 44100.
What is the relationship between frequency and the latency.
As per the concept microphone will have constant latency, can anyone explain why there is doubling in the latency value when sampling rates are altered.
le 08-26-2008 09:04 AM
Since the digital filters have a certain depth (a depth of a fixed number of samples), the slower you sample, the longer it takes for filter to fill up. So decreasing the sample rate for a given digital filter would cause more delay and increasing the sample rate for the same filter would decrease the delay.
However, changing the sample rate on some devices may put the ADCs on the device into a different mode with a different filter or may change post processing filters. So that's why I mentioned that as long as the same digital filter is in place, then decreasing sample rate increases the delay through that filter.
Hope that helps on that question.
DanO
Conditioned Measurements Hardware
