 jacky Wang
			jacky Wang
			03-17-2006 07:09 PM
 Ayman K
			Ayman K
		03-19-2006
		09:53 AM
 - last edited on
		02-29-2024
		03:44 PM
 by
		 migration-bot
			migration-bot
Hello Jacky,
From your post, I understand that you perhaps is generating Modulated signals using the RF-5670 and using an example program to do that but it has missing VIs. IF this is the case, then you are probably missing the Modulation Toolkit. The modulation toolkit is the toolkit that we use for modulating signals and further information can be found Here. You need to get the Modulation toolkit and install it to properly generate modulated signals. IF you are not modulating signals (generating modulated signals), then could you please Launch MAX and send me a screen capture of all the NI software that you have installed in your system (You could do this be expanding the Software section in MAX and print screen there). Thanks!
Ayman K
03-19-2006 07:15 PM
 Ayman K
			Ayman K
			03-20-2006 06:57 PM
Hello Jacky,
It depends on what you want to do with the PXI-4461. If you are performing some sound and vibration analysis, then you need the Sound and Vibration Toolkit installed. As for the support of your NI 4461 Card, you need the NI-DAQ driver to be installed. The toolkits that you mentioned and I mentioned about the Modulation are optional and dependant on your application. For instance, if you are generating a Modulated waveform, then you would need to have the modulation toolkit installed. Also, if you are performing Octave Analysis, then you would need the Sound & VIbration Toolkit.
Assuming that you need all of functionallity of the 4461, you would need the NI-DAQ driver, Sound and Vibration Toolkit and for the RFSG you need the NI RFSG driver and the Modulation toolkit. Please let me know if you have any further questions.
Ayman K
 sangbui_palpro
			sangbui_palpro
			05-04-2011 12:09 PM
Hi
niFgen doesn’t support PXI-4461; thus I can’t use soft front panel. Which driver/method should I use for continuous signal generation? Thanks.
SB
