Dynamic Signal Acquisition
Need help to measure Distortion on 115vac 400Hz
I got an PXI-4472 connected to an 115vac 400Hz inverter (voltage is adjusted from 115vrms down to 2.6vrms true resistors) to measure frequency and distortion in percent.
I have no problem reading the 400Hz frequency but when I try to use the Distortion Measurement VI (Signal Processing - WFM Measure - Distortion) I get nothing.
I want to read the distortion in percent.
How do I do that?
The frequency is allways 400Hz +/- 1%.
kls
(7,099 Views)
posting your vi would be of great help to help you 😉
Greetings from Germany
Henrik
LV since v3.1
(7,065 Views)
Also, please post a typical dataset with your VI.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(7,058 Views)
I am guessing you found your solution. For the next person with a similar question, please refer to the example VI Harmonic Analyzer Measurement that ships with LabVIEW.
If you want a simple test VI where you control the amount of distortion, you can try the following:
This snippet creates a fundamental tone at 400 Hz and a harmonic at 1200 Hz. When run, this VI returns the expected THD of 1 %.
Doug
(7,046 Views)
Accepted by Kimlorentz
Yes I was able to find my fault. I forgot to multiple by 100 to get the %.Smiley Very Happy
kls
(7,041 Views)
