Dynamic Signal Acquisition
I need the raw ADC output from a PCI-4462 using DAQmx
Is this possible or are only scaled engineering units availible.
Ken Manatt
kmanatt@jpl.nasa.gov
(9,664 Views)
Accepted by topic author kmanatt
There is a "Raw" version of DAQmx Read (see image).  That is probably what you are looking for.
-Alan
Message Edited by Alan [DE] on 05-19-2009 09:14 AM
(9,656 Views)
Thanks Alan,
This is exactally what I was looking for.
Ken
(9,646 Views)
Alan,
one question to the 'raw':
Is this the real ADC raw?
How about internal filter, calibration,compensation, scale, gain, oversampling, ... all that stuff well packed into the FPGA/Asic to squeeze the last bit out of the hardware ?
If you set the range to 0-5V and choose U16  0xFFFF is expected to be 5V, but what was the ADC(!) output?
Greetings from Germany
Henrik
LV since v3.1
(9,632 Views)
Henrik,
I think you will find the information here useful.
Message Edited by Burban on 05-20-2009 09:43 AM
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(9,620 Views)
Thank you Burban,
is there something similar about the digitizer PXI-5922 and PXI-5124?
Henrik
LV since v3.1
(9,555 Views)
Yes Henrik, use the niScope Fetch Binary VI to achieve similar results with a digitizer.  You can find this VI by dropping a niScope Fetch and then selecting a a 1D I8, I16, or I32 based on the resolution of your instrument.
Ben
(9,548 Views)
