Dynamic Signal Acquisition
How to measure high voltage AC (upto120 V) and acquire the output in LAB View, which equipment or devices to use. It would be preferable if i can get sampled instantaneous values to reconstruct the waveform in LAB View for analysis.
 I am Working on a project to monitor distribution transformer, need to convert the current and voltage output given by current and voltage transformers for measurement which is in range of 5 amps. and 120 volts resp.
(6,345 Views)
Consider the c series modules 9225 and 9227 for compact daq or compact rio
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,342 Views)
