Dynamic Signal Acquisition
DIAdem - Channel DataType Conversion
I have a tdms file which contains date,time and other data. The issues is all this channels have been acquired/created as String data type, how do I convert the data type of these channels to Date/Time or Float64 respectively? I tried allocating a new channel with respective types and passing the values but I could not achieve. Can some one please help on how I can quickly convert the datatype of a Channel?
I used DIAdem 11.1 in Windows 7 OS.
Wating for your earliest response..
Thanks in advance
Priya
(6,382 Views)
Hi Priya,
I'm afraid there's no very quick way to convert the TDMS channel data type. The data type of a TDMS channel cannot be changed once the file is written, I'm not very familiar with DIAdem, but I guess the situation would be similar. Maybe you have to read all the data values and then write them to a new TDMS file. It would be a workaround for converting the channel's data type.
(6,377 Views)
