My goal: To acquire a voltage output by an LVDT.
While using a multimeter or an agilent I have a measuring accuracy of the order of 5mV.
Otherwise, using two different cards: PCI 6013 or 6014 + CB68LP terminal and different ways (test on two different PCs):
The MAX test panels give me an accuracy of the order of 100mV! Therefore impossible to obtain sufficient accuracy with the LVDT.
Big noise, but where does it from??
Conf. Labview 2010, DAQmx 9.2.2
Help !!!!!
