Driver Development Kit (DDK)
Semi-period measurement with M series board using RLP
I'm trying to do a buffered semi-period measurement using register programming for M series board. I started with examples found in the forum but I doesn't work properly. The counter always increments instead od starting from zero for each measurement. I programmed the counter like discribbed in the DAQ-STC Technical Reference Manual and it doesn't work the counter still grows.
Can someone help ?
(7,660 Views)
Can you attach your code? what example did you used?
Regards
Manuel R
AE dans une autre vie
(7,629 Views)
I started with gpct_ex5.cpp provided with ni660x RLP examples. This example do a pulsewidth mesurement. Here's the code :
void
test(iBus *bus)
tAddressSpace cardSpace;
tTIO *board;
cardSpace = bus->createAddressSpace(kPCI_BAR1);
board =
new tTIO(cardSpace);
//Reset
board->G01_Joint_Reset_Register.writeG0_Reset(1);
//load initial value of 0
board->G0_Load_A_Registers.writeG0_Load_A(0x00000000);
board->G0_Command_Register.writeG0_Load(1);
//set source to internal timebase 3, the 80MHz internal clock
board->G0_Input_Select_Register.writeG0_Source_Select(30);
//set gate to external gate
board->G0_Input_Select_Register.writeG0_Gate_Select(1);
board->G0_Command_Register.writeG0_Synchronized_Gate(1);
board->G0_Mode_Register.writeG0_Gating_Mode(1);
board->G0_Mode_Register.writeG0_Counting_Once(2);
board->G0_Mode_Register.writeG0_Gate_Polarity(1);
//set second gate mode, to inverse of primary gate
board->G0_Second_Gate_Register.writeG0_Second_Gate_Gating_Mode(1);
board->G0_Second_Gate_Register.writeG0_Second_Gate_Select(30);
//primary gate
board->G0_Second_Gate_Register.writeG0_Second_Gate_Polarity(1);
board->G0_Counting_Mode_Register.writeG0_Alternate_Synchronization(1);
//set counting direction to up
board->G0_Command_Register.writeG0_Up_Down(1);
//arm counter
printf("counter value is 0x%08lx\n",
board->G0_Save_Registers.readRegister());
board->G0_Command_Register.writeG0_Arm(1);
//delay long enough to receive a complete pulse
long int i,j;
printf("waiting for an external pulse on the gate...\n");
for(i=0;i<5000000;i++)
if(!board->G01_Status_Register.readG0_Armed_St())
break;
printf("i is %d\n",i);
//read counter value
//since the counter is not armed the value won't change, so just read it once
if(!board->G01_Status_Register.readG0_Armed_St()) {
printf("counter value is now 0x%08lx\n",
else{
printf("Error: did not detect a full pulse on the external gate.\n");
delete board;
bus->destroyAddressSpace(cardSpace);
What I want to do is ti modify this example to make a continuous semi-period measurement.
(7,620 Views)
HI,
The counter ASIC of a M series device is a DAQ STC 2 and not a DAQ STC (E series deivce). M Series boards are now supported by the Measurement Hardware Driver Development Kit (MHDDK). You can use RLP examples programming with E series devices and not with M series as you can see on this link:
http://digital.ni.com/public.nsf/allkb/B08F4125A9325B3F862565CC0073E68F?OpenDocument
You will have more informations about the MHDDK at this link:
http://sine.ni.com/nips/cds/view/p/lang/fr/nid/11737
Hope this help.
Regards
Manuel R
(7,560 Views)
