Driver Development Kit (DDK)
corrupt visual c++ makefile for CIN/Labview
Hi.
I'm trying to run a simple Visual C++ file in LabVIEW by using CIN.  However, I'm having trouble compiling the source code in Windows.
I followed the online help and created a Makefile (buffer.mak):
name=buffer
type=CIN
cinlibraries=Kernel32.lib
CINTOOLSDIR=c:\Progra~1\Nation~1\LabVIE~1\cintools\
!include <$(CINTOOLSDIR)\ntlvsb.mak>
I saved this file in the same folder as my .c file, and then when I tried to open the .mak file into Visual c++ I recieved the following prompt:
The project 'buffer.mak' must be converted to the current Visual C++ project format.  After it has been converted, you will not be able to edit this project in previous versions of Visual Studio.  Convert and open this project?
I selected Yes, and then recieved the error:
Cannot load the project due to a corrupt project file
I'm at a loss of what to do, seeing as I can't load the .lsb file into LabVIEW without a working Makefile.
Any amount of help would be greatly appreciated. Thanks.
(6,829 Views)
(6,815 Views)
