Hello to everyone at NI
I have a question on NI 6519-DIO
The DAQ documentation I have downloaded for 6519 also covers NI 6509, 651x (includes 6519), 6520, 6521 and 6528.
According to this document (Static DIO register level programming) on page 1-3 there is a table called (Product Port Direction) which specifies all NI DIO devices port direction. However, the driver code seems to be for DIO 6509 which has 11 ports and all 6509 ports are bidirectional and programmable for Input or Output (I/O). Beased on this table, the device that we are using (DIO 6519) has 4 ports only and ports 0 and 1 are for Input and ports 2 and 3 are for outputs.
My question is, since the driver code seems to be for DIO 6509 which each port needs to be programmed for Input or Output, do I need to program the DIO 6519 this way or based on the document the DIO 6519 is already designed to be ports 0 &1 for Input only and ports 2 & 3 for output only and no need to be programmed for direction???
Can I assume that the specified ports 0 thru 3 of DIO 6519 are 2 for Inputs always (0 and 1) and 2 ports are for output always (2 and 3)?
Please be clear and specific in your answer. This is urgent and we are waiting on this to proceed.
I thank you for your quick respond in advance.
Thank you very much.
Lee Khadivi
Curtiss Wright Embedded Controls
