Driver Development Kit (DDK)
cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Driver Needed
I am using LabVIEW 5.0, I need the following drivers:
Manufacturer: Agilent Tech
Instrument Type: Power Supply
Model No: E3631A, E3615A
Developement Environment: labVIEW 5.0
Technology: IVI
Interface: GPIB
Anybody who have the drivers or know where to get the driver pls kindly let me know.
Thanks in advance.
Cheyne
Mensagem 1 de 5
8.397Exibições
If you haven't tried searching the Instrument Driver Network, you should try that.  Probably won't have drivers all the way back to LabVIEW 5 though.  Additionally, you might want to try posting to the Instrument Control forum page, here.  This message board is for driver development for NI hardware.
-Alan A.
Mensagem 2 de 5
8.374Exibições
As Alan mentioned, there are a variety of instrument drivers available from the NI Instrument Driver Network for your instrument, but none of them will work with LabVIEW 5.0.  I researched the possibility of using IVI Drivers with LabVIEW 5.0, but it appears that LabVIEW 5.0 was released before the IVI specifications were approved, so current IVI drivers will not work properly with LabVIEW 5.0.
You can read about this in this thread.
I would recommend that you upgrade to the latest version of LabVIEW, version 8.0.  This will give you the flexibility of using any of the Plug & Play or CVI instrument drivers which are available on our website, as well as a wealth of new features which are not available in your current version of LabVIEW.
Jason S.
Applications Engineer
Mensagem 3 de 5
8.369Exibições
If there is plug and play drivers, I can still use it. I don't know when my company will upgrade the labVIEW to 8.0. So, I am now headach with this labVIEW 5.0 as all the information provided in the NI website are based on the latest version.
Mensagem 4 de 5
8.364Exibições
This question has been responded to in multiple threads.  Please see additional responses to this question in the following thread:
Driver Needed
Mensagem 5 de 5
8.350Exibições
