Distributed Control & Automation Framework (DCAF)
module to only read tags
Hi all,
from what I understand only one UDP module can be paired with another one, so that each tag may have only one writer. That's fair enough but what if I wanted to have N readers? What if want to be able to spin up N instances of a lightweight "viewer" user interface that does not control but just displays data? Seems like it should be possible, as it is UDP after all- a many to one interface. All you have to do is listen and decode the packets. Any simple way to do this?
(4,182 Views)
Hi Mark, right now the UDP module doesn't support this but you could modify it to get that functionality. We are considering on having a Tag Viewer module but we haven't had time to make it.
In here the best option would depend on what your are using as  "lightweight viewer". If its just a simple VI you could create a new UPD module (modify the existing one) to just broadcast and then create the VI that is decoding the information.
Another option is you could create a module that uses a web service to publish the tags and then you could jus view the Tags.
Benjamin C
Principal Systems Engineer // CLA // CLED
(4,162 Views)
Hmm I'm kind of leery of using a web-service because then the cRIO has to handle requests which could come from many users and it has more important jobs to do. I'll look at modifying the UDP module.
(4,151 Views)
