Distributed Control & Automation Framework (DCAF)
DCAF Scan Engine Module import from project error
Hi all,
I'm using LV2017. When I attempt to pull in the data this happens. Any idea?
(5,470 Views)
MarkCG,
I haven't even gotten that far in LabVIEW 2017. I have tried to install DCAF Core 1.2.0.4 from VIPM and when I attempt to open Temperature Controller Example project I get a "Project or Library file is corrupt. Was able to open the example project in LabVIEW 2016.
LeMur Technology Services, LLC
(5,450 Views)
HI MarkCG, they made some changes in the project in 2017 and that is what is causing the issue. This is a new bug and we are working to fix it.
https://github.com/LabVIEW-DCAF/Scan-Engine-Module/issues/39
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(5,446 Views)
ah ok I can live without it for now. I'll start looking at github for bugs and report them there if new
(5,435 Views)
