Distributed Control & Automation Framework (DCAF)
DCAF Table API - auto conflict
Dear all,
I'm absolutely new to the DCAF framework. I've just installed it.
In order to evaluate it:
  1. I've read some documentation
  2. I've seen all the videos on the youtube channel (https://www.youtube.com/channel/UC45YcLDzXQ3dGi6GwfRdHtg)
  3. I've completed the Hands On material
My question is probably silly, but I can't Install the "DCAF Table API" using the VIPM.
When I try to install it I got the "auto-conflict" status in the VIPM:VIPM - Table API.png
If I try to install it (so I press the Continue button on VIPM) VIPM removes the "DCAF Core v1.3.0.12).
All samples and code I wrote seems to work correctly even if the "Table API" is not installed.
Sometimes when I open a DCAF projet I got the following Warning:
but again the code seems to work correctly and I'm also able to generate the exe file (tested on Windows only).
Some ideas?
Do I need the table API?
Paolo.
(4,580 Views)
Accepted by Paolo_Squillari
Hi Paolo_Squillari,
   You don't need the Table API package, all the VIs are already part of the core. We keep that package there for legacy purpose, other packages have marked it as not being compatible and that is why you cant install it.
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(4,576 Views)
