Distributed Control & Automation Framework (DCAF)
ADP5350 GUI demo
Good afternoon,
I downloaded the labview runtime engin 8.5.1 and after that i downloaded my the ADP5350 GUI and when i opened it show me a message " le VI n'est pas éxucutable. le système de développement labview complet pour corriger les erreurs".
what do I do at that moment??
Thanks and best regards,
(4,563 Views)
Hi Aymen55, basically there is an error on the VI you are trying to open, it could be that you are missing a driver or a library, and that is why it is not running. In order to debug the problem, you would need the full LabVIEW development version.
When you installed the UI did you installed the drivers?
https://www.analog.com/media/en/technical-documentation/user-guides/ADP5350CB-EVALZ-5350CP-EVALZ-UG-...
You posted this question on the DCAF support page, you might get more information contact Analog Devices support, or ask in the main LabVIEW boards.
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(4,552 Views)
Good morning,
Can you give me a link to download the full version of LabVIEW run-time engine 8.5??
(4,542 Views)
http://www.ni.com/download/labview-run-time-engine-8.5/861/en/
and more generally,
http://www.ni.com/downloads/
and search for required run-time version (such as  LabVIEW Run-time 8.5)
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(4,536 Views)
