La fonction de suggestion automatique permet d'affiner rapidement votre recherche en suggérant des correspondances possibles au fur et à mesure de la frappe.
To see the version
number of your application you can right click on the executable file
(the .exe file) and select 'Properties'. Under 'Properties' you can
find the file version number and description under the 'Version' tab.
If you want to display the version number in your program you could use the .NET invoke node and property node.
The System.Diagnostics.FileVersionInfo method of the .NET class will get the required information.
The attached example VI for LabVIEW 8 shows you how to set it
up. Remember this will only work if you cut and paste the code into
your program and build an executable. If you try to run the VI in
LabVIEW it will give you an error.
To try to get around this you can use the
'Application->Kind' property in the property node for 'This
Application'. You could wire the output of the property node to a case
structure and paste the code attached in the 'Run Time System' case.
