annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Debug teststand sequence from Labview
Hello all,
Is there a possibility to debug teststand sequence from labview ?  (go to next step, select step to execute ... etc
To be more clear, Is it possible to have this (see capture) from labview ?
thank you in advance
0 Compliments
Message 1 sur 3
1 732 Visites
Can you give more details why you want this available in an Operator interface in labVIEW. These functionnalities are for debug and are exposed inside sequence editor.
So if you want to debug a sequence inside your operator interface, I suppose that you have the sequence viewer inside it. in the labVIEw Full Featured User Interface Example, inside an execution, if you pause it, you can have access to this menu just by right clicking on sequence.
You can also have more functionnalities by using Ctrl + Shift + Alt + Insert
I found a tutorial in french about that
Regards
Maxime R.
  CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
  CTA - Certified TestStand Architect / Architecte TestStand Certifié
Message 2 sur 3
1 702 Visites
Thank you so much. It helped me a lot.
This is what I needed if it can help other people.
0 Compliments
Message 3 sur 3
1 667 Visites
