Digital Multimeters (DMMs) and Precision DC Sources
niDMM shows up in software list in MAX, but niDMM VIs are not in function pallet
How come the niDMM VIs are not appearing in the function pallet?  Even if I do a search on a particular VI, the search comes up empty.
(6,571 Views)
Roese,
Did you install LabVIEW before or after installing NI-DMM? If you installed NI-DMM first, the NI-DMM installer did not see LabVIEW on the system and so did not install the VIs for it by default. To fix this, rerun the NI-DMM installer, either from the disk or from Add and Remove Programs (Select National Instruments, Change/Remove, select NI-DMM, then choose Modify).
You may wish to refer to this KB (Part II) for more information. That KB is actually for NI-DAQmx, but it largely still applies.
Please let us know if this does not fix the issue.
Tobias Gordon
Software Engineer
Precision DC Software
Tobias
Principal Software Engineer
Driver Software
(6,560 Views)
