12-20-2017 04:46 PM
I use PCI-4070 to measure the Voltage and Current. The self-test and test panel display well, also display well on Windows device manage. But when I use NI-DAQ>>Aquire Signals>>Analog Input>>Voltageit , it said no supported devices found.
I am using LabVIEW 2016 version. Could anyone tell me why?
Solved! Go to Solution.
12-20-2017 04:59 PM
The PCI-4070 is programmed using NI-DMM, not NI-DAQmx.
I would recommend checking out the NI-DMM examples in Help->Example Finder to get started.
12-20-2017 06:37 PM
Thank you! You give me the right direction. I cannot find the NI-DMM examples in my LabVIEW following the guide form :
To browse the NI-DMM examples available in LabVIEW, launch LabVIEW, click Help»Find Examples, and navigate to Hardware Input and Output»Modular Instruments»NI-DMM (Digital Multimeters).
and as I try to follow the tutorial in link
http://zone.ni.com/reference/en-XX/help/370384N-01/dmm/lv_tutorial2/
But I find nothing about the measurement block in Functions.
I checked that the NI-DMM driver is installed.
Are there any problems?
12-20-2017 06:51 PM
What version of LabVIEW are you using? What version of NI-DMM? Did you install NI-DMM after LabVIEW?
12-20-2017 06:51 PM
PS, now my driver is version 17.1 and my LabVIEW version is 2016, is that the problem?
12-20-2017 06:54 PM
I have said on the first article. And the screen of the MAX is attached on it.
LabVIEW 2016
PCI-4070
NI-DMM version 17.1
12-20-2017 06:58 PM
That should be fine. Try reinstalling NI-DMM to make sure the LabVIEW support is installed.
12-20-2017 07:21 PM
It works for the driver 16.0
