Digital Multimeters (DMMs) and Precision DC Sources
PCI4070 NI-DAQmx - creating virtual channel - no supported devices found
I use PCI-4070 to measure the Voltage and Current. The self-test and test panel display well, also display well on Windows device manage. But when I use NI-DAQ>>Aquire Signals>>Analog Input>>Voltageit , it said no supported devices found.
I am using LabVIEW 2016 version. Could anyone tell me why?
Message 1 of 8
(6,235 Views)
The PCI-4070 is programmed using NI-DMM, not NI-DAQmx.
I would recommend checking out the NI-DMM examples in Help->Example Finder to get started.
Tobias
Principal Software Engineer
Driver Software
Message 2 of 8
(6,224 Views)
Thank you! You give me the right direction. I cannot find the NI-DMM examples in my LabVIEW following the guide form :
To browse the NI-DMM examples available in LabVIEW, launch LabVIEW, click Help»Find Examples, and navigate to Hardware Input and Output»Modular Instruments»NI-DMM (Digital Multimeters).
and as I try to follow the tutorial in link
http://zone.ni.com/reference/en-XX/help/370384N-01/dmm/lv_tutorial2/
  1. Open an existing or new LabVIEW VI.
  2. From the Function Palette (the default location), locate the NI-DMM VIs at All Functions»NI Measurements»NI-DMM.
  3. Select the VIs that you want to use and drop them on the block diagram to build your application.
But I find nothing about the measurement block in Functions.
I checked that the NI-DMM driver is installed.
Are there any problems?
Message 3 of 8
(6,205 Views)
What version of LabVIEW are you using? What version of NI-DMM? Did you install NI-DMM after LabVIEW?
GCentral
Message 4 of 8
(6,200 Views)
PS, now my driver is version 17.1 and my LabVIEW version is 2016, is that the problem?
Message 5 of 8
(6,199 Views)
I have said on the first article. And the screen of the MAX is attached on it.
LabVIEW 2016
PCI-4070
NI-DMM version 17.1
Message 6 of 8
(6,198 Views)
Accepted by topic author NewFifty
That should be fine.  Try reinstalling NI-DMM to make sure the LabVIEW support is installed.
GCentral
Message 7 of 8
(6,191 Views)
It works for the driver 16.0
Message 8 of 8
(6,182 Views)
