Digital Multimeters (DMMs) and Precision DC Sources
HP34972A Ethernet Driver for LabView 8.0
 I'm trying to use our new HP34972A meter with LV 8.0. I can only find drivers for HP34970A for LV 8.2 and higher that support the ethernet port. Do you have or can you make drivers for LV 8.0 that support the ethernet port on this meter? (I did find the serial port driver but would prefer not to use that interface).
Thank you.
(6,278 Views)
Hi fireman_bob1,
As you said, there is not an available driver utilizing Ethernet and LabVIEW 8.0 for the HP34972A. However, I recommend going to the Version Conversion Forum to see if the NI forum community may be willing to back-convert the components of the driver you have LabVIEW 8.2, to LabVIEW 8.0. Most of the driver components should be very similar, so this may allow everything to work with LabVIEW 8.0. Unfortunately, if it does not work, you may have to use the serial port driver.
Best Regards,
Thomas B.
Applications Engineer
(6,264 Views)
