Digital Multimeters (DMMs) and Precision DC Sources
Fast Short/Open Test using switch NI2510 and DMM NI4072
Hi Jared R.
i really appreciat your answer, many thanks,
i have tried this out, but with no luck, timing remain the same, i believe the time consuming operation come from the switching and not from DMM mesurement, because i have to Close/Open 4 relay do to one mesurement : here is a schema to simplify what i do exactly
and for each PIN in my DUT i need to do this same operation (120 pins must be checked) ,actually this is done in 6.67s but its quite big time,i hope i can decrease this to 1 or 1.5s.
by the way attached the code used with the software trigger,and FetchMultipoint stuff (C#).
may be this could help, here is the way i have programed Switch + DMM
initialize DMM
Loop foreach PIn inside DUT
Close PIN to HI DMM ( relay inside switch Card !)
Close PIN  LO DMM ( relay inside switch Card !)
Take Mesurement
Open PIN HI DMM ( relay inside switch Card !)
Open Pin LO DMM ( relay inside switch Card !)
end Loop
in the end of test Close DMM session
Many Thanks.
Best regards.
Message 11 of 20
(5,290 Views)
Hi every one,
any idea please ?
Best Regards.
Message 12 of 20
(5,269 Views)
When you said you already tried it, I wonder if it was by manually programming the multi-point acquisition or using the example suggested by JaredRo. Can you please let us know? If you haven't tried his suggestion, I strongly recommend you to run a few examples to see if the behavior seems consistent (the switch should be definitely faster than what you are seeing, given it is appropriately configured).
Camilo V.
Message 13 of 20
(5,249 Views)
Hi Camilo,
i have attached in a previous post, the source code used for multipoint acquisition (manually programed by me).
and here again you will find this source attached.
the problem here , is that i must close/open relays in the switch card befor makin any mesurrement.as i explained befor, the test must be done for each Pins inside the DUT. so the procedure is like so :
CLose to HI DMM
Close to LO DMM
Take Mesurement
Open Pin HI
Open Pin LO
move to next Pin....
and about the switch, im working the the NI 2510, topology used is 2510/Independent.
here is a part of the code to manupulate the switch
public Boolean ClosePinH_NIsw(string sDeviceAddress, string sSwitchTopology, string sRelayName)
try
//CloseSession();
Initialize_NIsw(sDeviceAddress, sSwitchTopology);
switchSession.RelayOperations.RelayControl(sRelayName + "a", SwitchRelayAction.CloseRelay);
// Wait for the relay to activate and debounce.
switchSession.Path.WaitForDebounce(maximumTime);
//Close session to switch module.
CloseSession();
return true;
catch (Exception)
CloseSession();
return false;
private string CloseSession()
if (switchSession != null)
try
switchSession.Close();
switchSession = null;
return "0";
catch (System.Exception ex)
return "Unable to Close Session, Reset the device.\n" + "Error : " + ex.Message;
return "0";
i have noticed that when we open a session with a switch for the first time it take 0.4 second, which is pretty big ???
Message 14 of 20
(5,239 Views)
Are you resetting the device every time you open the session?
I recommend you refactor your code to only open the session to the switch and the DMM once, rather than on every operation. And for further improvements you should program the DMM to do multi-point measurements using a software trigger to signal it to perform each measurement. If you want to take it even further then you could program the switch with a scanlist and have it handshake with the DMM using the PXI trigger lines.
Marcos Kirsch
Chief Software Engineer
NI Driver Software
Message 15 of 20
(5,232 Views)
Hi Marcos,
no i do not reset the device every time i want to open a session :
//true (default) Reset device.  false The device will not reset.
switchSession = new NISwitch(sPXIDeviceAddress, sPXIDeviceTopology, false, false);
in first place if we want to open a session to Switch it take about 0.4s :
the reason why i do not initialize the switch only once, is because i have 13 switch to control, and target relay could be at any switch, so in order to close a relay i must identify the switch name + relay name :
and i could not do multipoint mesurement by DMM because i must every time change pins where im taking mesurement.please refere to previous post.
have you any idea ? may be im doing something wrong ?
Message 16 of 20
(5,223 Views)
Hi Marcos,
Message 17 of 20
(5,223 Views)
I don't understand if you mean that the first time you open a NI-SWITCH session it takes 0.4 s, or if you mean that everytime you open an NI-SWITCH session it takes 0.4 s. This seems like an excessive amount of time but I don't know what system you are running this on.
You should still initialize the session to each switch only once, and then reuse the open session, rather than open and close every time.
As far as other performance improvements, maybe do a little bit more benchmarking and let us know where things are taking a long time.
Marcos Kirsch
NI Driver Software
Message 18 of 20
(5,207 Views)
Hi Marcos,
i could not open a session with 13 switch in the same time,
to control a switch i need to open one and only one session identified with the switch name and the topology
//Creat switch Session
switchSession.DriverOperation.Warning += new System.EventHandler<SwitchWarningEventArgs>(DriverOperationWarning);
once this session is created then i can control relays inside the opened Ni switch card :
//Close Relay in the opened session
i will do some trials, and let you know.
Best Regards.
Message 19 of 20
(5,201 Views)
I think there's a misunderstanding.
I'm telling you to open 13 separate sessions and keep them all open at the same time, not "a session with 13 switch in the same time". That means you will have 13 instances of type NISwitch, one for each device. Then you call RelayOperations.RelayControl on the correct instance based on which switch you need to act on.
Marcos Kirsch
NI Driver Software
Message 20 of 20
(5,197 Views)
