07-27-2006 12:42 AM
07-27-2006 10:23 AM
07-27-2006 11:11 AM
07-27-2006 06:58 PM
07-28-2006 12:33 AM
08-11-2006 09:22 AM
HELLO ALL,
CAN SOMEBODY HELP ME FOR SIMULATION OF THIS INTERFACE(MULTI FUNCTION VEHHICLE
BUS,PC/104:PROFIBUS,CANOPEN INTERFACE,RS -232,RS-485) WITH CPCI BACK PLANE.
IT'S TYPE OF DATA RECODER APPLICATION IN RAILWAY'S, I WANT TO SIMULATE THIS INTERFACE WITH
REAL TIME APPLICATION IN LABVIEW, & I AM BEGINER TO LABVIEW. IF SOME EXAMPLE'S AVIALABLE PLZ SEND ME.
BEST REGARDS
ARIF.
email:-arifahmedmd@infotechsw.com
08-14-2006 11:53 AM
08-14-2006 12:13 PM
Iam currently working on Labview and new to this Labview.
It's type of data recorder application in locomotives and i have to simulate signal to my hardware.
sub modules of this data recorder are:
Profibus
MVB bus (multi vehicle bus)
I/O modules
In i/o modules we will be needing the below mentioned signals:
3 Frequency inputs to data recorder
2 Analog inputs to data recorder
4 Digital inputs to data recorder
2 Analog outputs from data recorder
6 Digital frequency outputs from data recorder
12 Digital inputs to data recorder
4 Relays
We will be needing to generate and read all the above mentioned signals in Lab view using TCL(Tool Command Language) script language.
And also we will be needing to communicate to MVB bus card and Profibus card using Lab view and we need to implement these two protocols in Lab view using TCL script.
We will be grateful if you can help us in this regard.
Arif
08-15-2006
07:02 PM
- last edited on
04-15-2025
08:55 AM
by
Content Cleaner
Hi Arif,
Your application sounds like it covers many areas. If you are new to LabVIEW you may want to familiarize yourself with it before you begin coding. There are various tutorials and example programs online for different applications. A good basic tutorial is the three hour LabVIEW Tutorial.
Also, if you are looking for someone to set this system up for you, National Instruments has an Partner Network that consists of hundreds of developers, integrators, and industry experts that offer solutions to customers.
There are some other forum posts that discuss using TCL in LabVIEW. There is not a built in interface for it. You would basically have to access the script from a dll.
Hopefully this is a starting place.
Adam W
08-17-2006 08:05 AM
Hello Adam
My Application is read script file from TCL for different interface and update(display)or configure the data in front panel of GUI through that i have to select the port of different interface depending on input's range.
our interface are:
MVB BUS
PROFIBUS
CANOPEN CARD
ANALOG I/O CARDS (two analog input's and two analog output's)
DIGITAL I/O CARDS ( two digital input's and two digital output's)
RS 232
RS 485
I have found 1 vi from NI disscusion form,from which will read the TCL script and display in output string, iam attaching that vi with this mail, plz u go through and find it suitable for my application for read script file for different interface.
ARIF
