06-10-2009 04:34 AM
sir i have a rotary encoder of nemicon corp. model no. NOC-SP2500-2MD-10-100-00.
It has 8 wires for connections like this-
red = +5v
black = 0v. common
green A blue A bar
white B gray B bar
yellow Z orange Z bar
i connected it to ni usb module NI 9411 like this
red - 4
black - 12
green A - 1
blue A bar - 9
white B - 2
gray B bar - 10
yellow Z - 3
yellow Z bar - 11
but when i opens my daq it tells no device is connected or if i runs any example then it tells no power is given to device. i made only these connections. please tell me where is the problem in it . i am using rotary encoder first time.
Solved! Go to Solution.
06-10-2009 11:23 AM
Do you have a 5-30VDC power supply connected to Vsup and COM?
-AK2DM
06-11-2009 04:11 AM
06-11-2009 10:45 AM
The manual says if you need to power the device (ie encoder) you need to connect an external supply. All the examples in the manual show an external supply.
http://www.ni.com/pdf/manuals/373506c.pdf
I re-read your original post again, it appears that MAX or LabVIEW cannot detect the 9411? Did you install the drivers?
-AK2DM
06-12-2009 08:50 AM
sir
i can get now digital output from tha rotary encoder , can u send me any simple example of measuring angle or angular speed.
thank you for replying me.
06-12-2009 09:42 AM - edited 06-12-2009 09:43 AM
Under LabVIEW Help, select Find Examples and search on encoder. I think there are some vi's in there already written that are compatible with your hardware.
What solved your issue? Adding the external supply or installing the drivers (or both)? EDIT- I see you marked the power supply as the solution.
-AK2DM
06-30-2009 05:18 AM
sir
i connected my encoder to labview and now it is giving us a value of 0 & 1. i tried with every example but it is not working. somebody told me that it is a mechanical encoder so its vi will be different. i send u all the information about the encoder in mine first problem. which diagram will help me.
or please send me a simple vi which is easily understandable.
please reply.
