thank you very much for your advise now i'm about to finish the
function i can see the signal and the changes of the time interval
on the wavediagram of the frontpanel but the problem that i don't
get the expected signal at the digital output line17 from the DAQmx
actually there is no output at all from line17 however there is no error message in the code when i run the simulation
i chose another output as an alternative but still there is no
output signal too however i checked these outputs with another
code
to test them if they work or not and the answer was positive also
with the testpanel they react with the changes which means
that configurations of the DAQmx is right
in my code i changed the rate many times to be able to see signal on
the oscilliscope not only in µs but also in different dimentions of time
but still there is no output
all of this mean only i have something in the code which i don't know is the reason of not getting the output signal
i send my code as an attachement may be you can try it and tell me where is the reason
i have labview version 7.1
my device is NI-PXI 6259, it has 32 bit port
thank you very much
