Digital I/O
digital pattern output
I am new in labview and need some help.
Can I output cutomised digital 10bit pattern on usb6009?
(3,903 Views)
Hi Andylwk
As a good start point I would look through the example finder in LabVIEW found on the startup window or from the front panel or block diagram by clicking on Help > Find examples..  Here you will find some good examples.  If you have further questions after doing this then post back and I will look into your query.
Regards
Matt Surridge
(3,651 Views)
