Digital I/O
USB-6453 - How to Drive Relays
I want to submit this device for our test racks.  For what we're doing, this covers the task (with some additional external hardware).  But what's got me perplexed and I was hoping for some help, how does anyone use this to drive relays?  The current out for the digital I/O is very low.  The DIN rail SSRs I'm looking at I believe need something like 100mA.  So how do others drive relays without building a custom board?  I don't see any DIN rail mountable relay driver boards.  Anyone got any advice?
(804 Views)
How many relays are you trying to control?
In a previous project, I used a NI-9482 in a cRIO to control a relay. A cDAQ would have done the job, but I was already using a cRIO for other reasons and still had an open slot. This module is a 4 channel relay module that I used to switch +24V to control an AC power relay.
(797 Views)
6 relays to remain on continuously, an additional 6 relays to alternate on/off.  No more than 500mA through each relay. I looked cDAQ route, but I'm trying to justify this change via cost and the cDAQ route quickly doesn't allow that with my AI needs.
CDAQ route gets up to $4500.
(784 Views)
Usually the DIY arduino relay boards works with digital signals and would work with 6453 digital outputs. Since those are not industrial, I would recommend inserting an opto-isolator to support larger current to control the SSR.
6453 DO --> optocoupler --> SSR
Santhosh
Soliton Technologies
(766 Views)
